the fret ends are blind, which is fantastic, and has a GREAT feel to it, tho i noticed there are no side dots..... something im probly going to add when i can.
I had to have the bridge holes drilled for me, and there are slightly off, but its good enough to me.
I had to get some all thread and specialty bolts. cuz the trem plate is o.g. but the rest was long since gone, so i just kinda rigged up a lil hard tail jobby and it works great.
there is a slight short in the jack, in reality its just dirty. i got in there and cleaned i the best i could with some fine grit paper and a rag. in reality i need to probly retouch everything to make it gig worthy, but for what im doing its fine, and only shorts out of i push on the cord against the jack in an unatural fashion.
anywho... PICS
the bridge pup sits so FUCKING HIGH! that i had to use the neck plate as a shim for the neck! it just barely clears the bridge pup and in reality it still needs to go down about -3 more millimeters. but, we all know that they arent ajustable.... sooo
originally the bit of wood was still there(the spot that has no wood)
and i was going to clean it out and relue it down the best i could, but when i pulled it off, i promptly lost it... no fucking idea where it went... so i just kinda smoothed it out a bit, i was going to put a strat like contour on it, but decided that was alot of work for nothing, and it looks cooler with the "kurdtz" style damage.
either way. its badass.
I gotta thank pens a million times over for sending this my way, it kept me busy for a lil bit and now i have a guitar to play, and all i did was pay like 10 bucks for shipping or something like that. THANKS MAN!
and also, the person that stepped out of line and let me have the geeter. thanks to you as well. i also have a lil tiny mini "belt buckle" amp that i got for 10 bucks the other day with built in over drive, so im officially on my way back to rocking faces and melting panties!
