I made a OLC Shred Meister a ways back. I am interested in a project, so I thought I would give the BYOC Shredder a go. I know the OLC pedal isn't a clone, but I hear the BYOC is so I am curious how they sound A/B. (Plus I like wiring and I like making pedal art.)
Whats the gain like on your OLC clone? With my original Shredmaster, it doesn't start to get really dirty until around 2 oclock. Full up its pretty distorted though.
71Smallbox wrote:Whats the gain like on your OLC clone? With my original Shredmaster, it doesn't start to get really dirty until around 2 oclock. Full up its pretty distorted though.
The kit came in so I got to work on it. Put all the parts out in order and got ready to solder. I wanted to wire stuff up and test it before I worried about the decal and stuff to avoid having to take it apart and back together when it is decaled and messing that up.
Messing with the knobs.
Your build gets dirtier alot quicker than mine, I wonder if something is up with my OG pedal?
Weird, why does this only have 1 opamp? The MKI Shredmaster has 2, I believe they're TL072's. Maybe its utilizing a quad opamp instead of 2 dual opamps.
71Smallbox wrote:Weird, why does this only have 1 opamp? The MKI Shredmaster has 2, I believe they're TL072's. Maybe its utilizing a quad opamp instead of 2 dual opamps.
71Smallbox wrote:Your build gets dirtier alot quicker than mine, I wonder if something is up with my OG pedal?
Maybe OLC's version upped the gain?
OLC website wrote:OLC Shredmeister
The one and only Shredmaster clone. OLC doesn't produce much in the way of clones, but this was born from a request I received several months ago. After building a prototype, I realized it was an excellent distortion pedal. It has been modified for more gain and more control in the tonestack.
Yup
I'll have to look into what was component was changed for the gain.
If your pedal is the same size as the one they send, I could just mail you one of mine to apply. It is just a waterslide. I normally print out three to be safe and almost always just need the first one.
Oh and I did change it slightly. I will post a pic because I am going to apply it tonight. I got rid of the white boxes under the volume/tone/etc. I also added "OK" before "SHREDMASTER" so it reads "OK SHREDMASTER"
I use a razor and drag it against the edge around the circle lightly and the little decal circle falls through the hole. I don't poke it through the decal, just gently scrape the circles edge.
