wwrrss wrote:WHAT IS AN JEFF?
Mezz is filtering the facts. That should read
current. I relaxed. He got me.
how can i test the mosfets incase they're dead too?
I could do with a better pic than this, cropped from an ad on the net.
Does any of the four big resistors look as thought it's had a hard life? That would be a clue if one MOSFET had gone short-circuit.
First cut; measure with a meter. You could really do with one that measures low resistances. Measure between the case of the 2SK134/2SJ49 and the end of the nearest big resistor to each transistor. You may be looking for the difference between a dead short and .66 ohms (+/- 10%)
If you know your way around electronics, circuit diagram is at
Dr. Tube though this is slightly different to yours as they have two output inductors, CH1 and CH2, in parallel.
If the choke got that hot, you may also find that it's affected the solder joints to the board. Hopefully no tracks on the board are fried.
