I checked out Facebook marketplace and saw this listed for $50 10 minutes ago. The seller claimed the overdrive channel didn’t work and it was recently retubed so that’s not the issue. He messaged me on the way over that he just tested it again and the distortion channel did work but since he wasn’t confident it would stay working he’d still sell it to me for $50. I didn’t make change on my way over so I paid $60 but still feel kind of bad about it.
It works perfectly fine. Spring reverb works great too. TBH I’m not a big fan of the dirt channel anyway but it seems to be working just fine, all I can think of is maybe a cracked solder joint on the pre/post pots. As long as the normal channel sounds this good I’ll never use the dirt anyway.
I should have bought one of these years ago. Smaller and lighter than my DRRI and at least as loud.
I remember going to play with one in a guitar shop in Belfast, and I was fucking good at this point. I remember sort of panicking though and getting like, stage fright playing it. Then the guy in the shop came and took the guitar off me and sort of played open chords and stuff to show me what it could do. I remember being furious, but polite. Sort of just saying "aye, naw that sound good alright" as he played the odd barred chord and sowed me that on this model you could also use the distortion to play powerchords too.
Freddy V-C wrote:Absolute bargain! The Classic 50 I bought a few months ago is a total beast, and the clean channel is crazy good.
Do you think you'll be in a position to crank it any time soon?
I had it at a pretty loud volume to test it for a bit but the band I play guitar in (The National Physical Fitness Award) is having our first post-COVID practice this Tuesday so I’ll probably test it out in a band setting then.
Bacchus wrote:Am I imaging this, or was the OD channel called Distortion instead?
Also, was the original not called the Classic 30?
The channels aren't labeled from what I can tell, there's just a "channel" button, as well as pre/post controls and a boost switch. Unless the channels are named on the footswitch, which didn't come with the amp.
Vlassic was a noticed typo but I decided to leave it because it's the best tasting Peavey I ever heard.
Peacy Vlassic. This is an unfunny joke now, but give it twenty years, these will be vintage and there will be clones called Peacy Vlassic that will go for about half what we earn in a year.
I'm sure there was some amp where the overdrive was called distortion......
Anyway, still jealous, still wishing you luck with it.
As much as I like this thing, the harsh highs on cleans are just too much out of the stock speaker at anything over bedroom volumes. I ordered a Cannabis Rex from my friend's shop today, it should be in next week. I've only read good things online from people who swapped it into their classic 30's for the same reason (tamed highs, warmer sound that doesn't break up as early).
I cant imagine living my life not being able to play loud as fuck when ever I wanted during the day
Can’t your neighbours hear? I will crank it for 10/20 minutes, but that’s gigging volumes and would be inconsiderate to do for any longer.
Basement that's about 5 feet underground - carpeted, panel walls and drop acoustic tile ceiling. With the staircase doors closed, it's not that loud upstairs let alone outside. With a full band you can hear it in my backyard/driveway. I live in a neighborhood full of 50's ranch houses that are far enough apart.
I still try to keep volumes down a bit after 10 just in case, but this summer people have been setting off fireworks sometimes as late as 11pm so fuck it.
