Pressing tracks to vinyl.
Is this an expensive proccess? I am recording in september, but aswell as pressing the tracks to CD I would like to press a couple to vinyl too. Anyone got any sort of experience with this type of thing?
Depends how many you want pressing really - if you literally only want a 'couple' pressed then it wouldn't really be worth your money. Infact I'm not even sure you can get them pressed in single quantities. Like anything I think it tends to start getting cheaper the more you have pressed...
Searching in Google seems to yield a fair few results so just have a scout around and I'm sure you can get a good deal from somewhere.
Vinyl Pressing
Vinyl Pressing
Thanks a million for that. I wouldn't want too many doing, due to the, somewhat, lack of interest in vinyl these days. But if I could get maybe 50 ish done, I think that would be a really cool thing to have! I have a pretty small but decent collection of vinyl myself so this would be great. Thanks again for the link!
You'd be surprised, loads of people still love vinyl! A lot of bands start out doing limited runs of 7" singles.kingoftherodeo wrote:Thanks a million for that. I wouldn't want too many doing, due to the, somewhat, lack of interest in vinyl these days. But if I could get maybe 50 ish done, I think that would be a really cool thing to have! I have a pretty small but decent collection of vinyl myself so this would be great. Thanks again for the link!
I guess the sensible approach would be to get as many pressed as you thought you could realistically sell. Don't go spending a fortune on a 1000 run pressing when really only 100 people may buy it. That's just common sense though, I'm sure you know that.
It does seem a little pointless to get them pressed in Europe just to sell a small amount. Thanks.stewart wrote:I've looked into it before and it's expensive, especially in the uk as there's only a couple (maybe even one) pressing plants left. Some brokers will get them pressed in europe, as costs are often lower. If it's just for the sake of vanity i wouldn't bother.
- stewart
- Cunning Linguist
I meant the company you go to will sometimes get the pressing done in europe, which makes it cheaper for you, if you catch my drift. When you get vinyl pressed it's generally done through a 3rd party of some sort. If you approach a pressing plant yourself they'll likely tell you to beat it. Hope that makes sense... I'm essentially saying 'shop around'.
This is from customrecords.com, a novelty one-offs dealieserfx wrote:the mixes for vinyl, and cd should be different as we hear both formats differently, unfortunatly i can not find my notes on mastering for vinyl vs mastering for CD, i suspect they are sitting at the jam studio.
I don't know how good these guys are - but they do the mastering for you as well: Mobineko
- UlricvonCatalyst
Unless you have money to burn, pressing up 50 vinyl copies is an expensive indulgence.
The biggest expense is in set-up costs, so the unit cost of vinyl gets cheaper the more you have pressed.
As a guideline, the set-up cost alone for a double-sided 7" single (from Portalspace Records) is just over £400, not including label set-up and printing charges.
exactly. the expensive part of the process is making the master, negative, mother, etc. that takes experienced technicians to to do that and it's a pretty complex process. once they have that though, they can press a ton of copies and it doesn't cost very much. some videos on the process:UlricvonCatalyst wrote:Unless you have money to burn, pressing up 50 vinyl copies is an expensive indulgence.
the part that they skip over in that first video they explain a bit more here:
You say that, but it's very much the done thing to do in underground punk/indie/metal circles. I guess those kinda genres inspire more High Fidelity-esque fanboyism and "snobbery" than your standard rock music though.kingoftherodeo wrote:Thanks a million for that. I wouldn't want too many doing, due to the, somewhat, lack of interest in vinyl these days.
Ive run into a split 12 inch recently, which was nice. It would all depend on how long your release is.
If you were working on a longish e.p, then find another local band looking to do the same thing, and do a split, each album on one side.
At least with that, the cost would be split in half, and you would be (logically) selling double the quantities. That many more people will hear your music.
