Newbie requests buying advice
Hi all
I'm retired and in the UK. In about 1966 I was the proud owner of a Rickenbacker 1996 but I sold it when I ran out of money in Spain the following year. These days I want to buy something to play with as much as play on, retirement fun you might say. I neither have the talent to justify the investment nor the money to just go and buy one anyway. (Well I suppose that last bit is a lie, but still it's not really justified).
I have bought a mini strat which I think is about 22", but still more than the 20.75" of the Rick. Are there any short scale guitars in production at that 20.75 length with narrow necks?
The mix of aching older fingers and small hands has made a short scale even more significant now than it was 44 years ago!
John
www.motorhomeradio.com
John
- StevePirates
- mtotallywired
Yes it would, but the RV and the Boat and my winters in Spain keep me permanently poor. It's a hard life! Actually the only problem with being retired AND divorced is being an old git, only Grannies want to sleep with me; and who looks at Grannies unless you've been living with one for 40 years.mtotallywired wrote:A Ric would be a nice retirement present though, wouldn't it? mmmm...retirement.
Thanks for all the advice. I'll check out the mini bullet thingy today.
BTW I also have a J45 and a Harmony H77, the latter is impossible for me to "Chuck Berry" on, my little finger just can't get there.
Loved the Lou Reed quote.
John
Hmm, I've sent them an enquiry, thanks for the link. However I'll give good odds that this is a typo and the actual length will be 22.75 same as all the other Squier Mini strats.
John
uuu, sweet an harmony h77.
Thats a great guitar..
Hope You find something suitable.
Eastwood has some nice guitars here , but the shortest is 24" .
Item name: 1/2 size Electric Guitar kit with amp, strap pick, case!
Item Id: 220775913843
Dear corneliusjrat,
Hi, Thanks for your question. The length from bass end bridge to nut is
around 20inches. Hope this helps. The bridge is adjustable for each
string
Best wishes
Charlie Watts
-charliewattstesters
- StevePirates
False advertising jackanapes.milltech wrote:
They've confirmed to me that it's an error in the description. I've seen it before in other products, when preparing a web page it's SOOOO much easier to use someone else's than type it all over again, and if they got it wrong it becomes viral, (to use a trendy word - God but I'm so hip!).
I misread that as japanese for a split second.StevePirates wrote:False advertising jackanapes.milltech wrote:
Yell Like Hell
- StevePirates
You might consider the Epiphone PeeWee series
19" scale
http://www.epiphone.com/news.asp?NewsID=1955
19" scale
Thanks for that one, from the description it might just be a bit too clunkyly basic for me, but a kind thought.NickS wrote:
Item Id: 220775913843Dear corneliusjrat,
string
Best wishes
Charlie Watts
Wonder what "a full sized neck" means? Can't find a full spec but I'll keep an eye open for one to play with.StevePirates wrote:You might consider the Epiphone PeeWee series
19" scale
Thanks for all the comments, much appreciated
John
Stagg makes a small strat. I have one that I use when I go on family trip. You can pick them up for around $70. http://www.staggmusic.com/products/prod ... &oneid=404
off the top of my head it is around 19" scale
