vintage time machine!!!
Posted: Mon Oct 13, 2008 9:08 pm
i found this, it's almost free compared to dmm, has anyone used or compared them?
You sure? i saw a concert today, i'm sure the guy was using one!!!!Hurb wrote:behringer have also been teasing us with the promise of them for like two years.
It looks like the deluxe big muff, i think...James wrote:What's the tube monster copying? That um.. muffin thing? Or hot tubes? I'm guessing names a bit but theres some EHX stuff I'm sure.
It was a webcam of Hurb coquetteishly soldering in bed and making "ooh" faces at the camera, shortscalers.Hurb wrote: I made benecol think I had one when he saw the picture of my pedals. so it could of been that.
I won't buy one before trying it, specially because everyone in my country thinks behringer=shit, so i probably would have to keep it for lifeDuoSonicBoy wrote:They're listed as in stock on a few UK and German websites. They're illegal here in the US, though. I found one site that had a few, but they wanted >$100.
It's probably exactly the same as the real thing - I say go for it.
?? Just that specific model?DuoSonicBoy wrote: They're illegal here in the US, though.
A couple of 'em are, Time Machine is the only one that comes to mind.paul_ wrote:?? Just that specific model?DuoSonicBoy wrote: They're illegal here in the US, though.
Those footswitches are boss-style PCB mounted ones with fake spring-driven tops on, btw. Wouldn't bother me but the bypass on the big muff copy is welllll shit and I don't know how to change it.
You don't have to disable the circuit at all. You just switch it on and then wire it in TB style.DuoSonicBoy wrote:A couple of 'em are, Time Machine is the only one that comes to mind.paul_ wrote:?? Just that specific model?DuoSonicBoy wrote: They're illegal here in the US, though.
If you don't mind keeping the stock bypass scheme, you could just hack in a higher quality momentary (normally off) footswitch. Otherwise, you would have to at least take the PCB mounted jacks off and disable the LOGiC circuit.
In most schemes I think you do have to disable it (at least you have to in Dano minis and BOSS). Otherwise you'd just be switching between true bypass and buffered bypass. It's not a big deal - there should be lots of information on the DIY stompboxes forum.Mike wrote:You don't have to disable the circuit at all. You just switch it on and then wire it in TB style.DuoSonicBoy wrote:A couple of 'em are, Time Machine is the only one that comes to mind.paul_ wrote: ?? Just that specific model?
