After doing some idiot checks, I discovered that something was seriously amiss. In bypass (as expected) we have normal tone straight from guitar to amp, but with the pedal engaged on either the rhythm or lead circuit and with all levels turned up to maximum, I can hear a little bit of the guitar sound coming through but it's mostly this aforementioned hiss. Having said that, sometimes when I turn it on now it's completely silent with all the levels turned up (again normal in bypass as expected).
So, I assume that one of the valves has gone pop (apparently the 6021 valves in this pedal are supposed to last much longer than 'ordinary' valves theoretically making this unlikely)? Is this hsshhhhwharrringg classically symptomatic of that or could it be something else? (I appreciate that's a fairly open-ended question)
Thanks in advance as always
