Jagmaster modding
Posted: Thu Jan 19, 2012 5:22 am
by ChrisFFTA
WOuld it be possible to put a Jag trem set up on one of those silver sparkle Squier Jagmasters?
Posted: Thu Jan 19, 2012 5:32 am
by mkt3000
Anything's possible with enough time and money.
But this would be a pain, especially when you go about filling in the gap the strat trem leaves behind and try to match the finish.
Posted: Thu Jan 19, 2012 9:16 am
by Fran
mkt3000 wrote:But this would be a pain, especially when you go about filling in the gap the strat trem leaves behind and try to match the finish.
This.
The Jag trem itself is really easy to fit, it is surface mount and only requires a small route.
If you got a custom guard cut to extend over the area you would have to fill then fit a TOM, it
may look okay. It would be worth making a diagram first to see if it does look okay.
Posted: Thu Jan 19, 2012 3:10 pm
by brainfur
every time I start to work on a guitar I end up playing bass after about 10 minutes.
