best hard case for mustang?
- thepossiblebag
hi,
can anyone recommend a good hard case for a 65 RI mustang guitar?
thanks!
thanks!
- honeyiscool
My Stang fits in the Gator case just fine. I just have to squeeze it in a little (that's what she said) to fit the headstock in.
There's a Kaces soft case I have that I really like. I used some felt inserts to make the guitar fit better but it's the most useful guitar case I've ever had.
Kicking and squealing Gucci little piggy.
- thepossiblebag
Re: best hard case for mustang?
I prefer the SKB cases both for fit and price, but couldn't find one for my Cyclone, which shares the Mustang's body, so I purchased a Fender deluxe mustang case which I do not like. What I don't like? First the guitar's neck runs through the storage compartments, so what ever you put in there, like your tremolo bar, strap, picks, wrenches, tuners, etc, can bang up against the neck. Second I don't like the lock. It's the cheap type that you typically see on a suitcase or low end guitar cases that can be picked with any small flat-head screwdriver or paper-clip. The SKB locks are nice and solid and latches are flight approved. I have a Gator case for my Jagmaster and it's similar to the Fender case, but the storage compartments have flaps/doors over them to keep your gear from banging around. However, I have the same complaint regarding the lock on the Gator, it's cheap. The Gator is the least expensive coming in right around $99.00, Fender ~$129.00, SKB ~$134.00. If I ever find that SKB has a case for the Mustang, then I will be obliged to dump the Fender and replace it with the SKB.thepossiblebag wrote:hi,
thanks!
- gypsyseven
- Johnny Noir
- honeyiscool
I somewhat agree. I use this case a lot:h8mtv wrote:I really think a good padded gig bag protects better than a hard case. Just my personal opinion tho.
http://www.musiciansfriend.com/accessor ... 2000000000
It's sort of like a soft case that protects like a hard case. Also has backpack straps and stretchy pockets for cables and shit. I love this case so much.
But a couple of sheets of felt are recommended (get them at an art store).
- hotrodperlmutter
- crescent fresh
Yes, genuine Fender G&G Strat cases fit, however, I had to modify mine, cut the padding in half on the ass-end, and move it to the top (not front) side. I razor-bladed the pads off the side wall, peeled back the velvet, removed the styrofoam and cut it in half lengthwise, then inserted the two chopped off halves into the side front wall of the case, then re-covered the styro pads with the velvet which now had extra slack, and the front wall had enough slack to still connect with the wall without leaving any gaps. It was too tight in the ass and too loose at the top. I accomplished this without destroying the crushed velvet or leaving any visible alterations. Now it fits snug as a bug.
- hotrodperlmutter
- crescent fresh
This one might suit the bill. It's a Fender case,but unlike mine has the closed pocket for storing your accessories. About $50.00 more than I paid for my Fender case without the closed storage compartment. Here's a link to ebay for them.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... SS:US:1123
That looks just like the case I bought for my Musicmaster II, which is the same size/ shape as an original Mustang.
I got mine from Elderly instruments, it was a long time ago but I think it is this one:
http://elderly.com/accessories/items/GCF-TXMUST.htm
(FWIW it fits my Musicmaster II perfectly)
MMPicker wrote:That looks just like the case I bought for my Musicmaster II, which is the same size/ shape as an original Mustang.
Hhhmmm? No pic currently to compare it to, but there is a pic for the Fender Mustang Bass Case that looks the same inside. Better price at Elderly if it is the same case.
Damn it! I finally realized that my case is based on the 60-70's vintage style and that's why it's all open inside. Definitely not a fan of the vintage cases.
Disciple of Pain
"I'm like the monkey screwing the skunk. I haven't had enough, but I've about had all that I can stand!"
"Born to Lose. Live to Win." Lemmy Kilmister
