Shortscale's favourite tubes
Posted: Mon Feb 17, 2014 9:28 am
by Viljami
As a recent member of the Tube-Amp-gang (well, a hybrid TBH) I was wondering what tubes do you use/favor? Is there a big difference between say, different brands of EC83's?
Posted: Mon Feb 17, 2014 2:43 pm
by Fakir Mustache
You mean ECC83.
I prefer JJ. Others can be too harsh, although those may have their place too in a dark amp I suppose.
Posted: Mon Feb 17, 2014 3:31 pm
by way of necessity i have these http://www.hotroxuk.com/tungsol-5881-6l6.html
since i changed speaker the magnet is much bigger and due to the compact design i can't fit full length 6L6 tubes in it, but these are shorter than regular 6L6s and have a slightly lower bias and run slightly cooler. apparently they have a slightly stronger midrange and keith richard uses them a lot (or something).
also, tung sol 12ax7s are often cited as some of the best modern production preamp tubes available. i have some of those as well.
together they sound very nice
Posted: Wed Feb 19, 2014 9:32 am
by Gabriel
I used Tung-sol the last time I changed valves. Currently I'm running JJ but that's just what came in my amp, but I do actually need to change them soon.
