Noob pedalboard/power question
Quick question: I've rearranged my pedalboard today. Sounds good, except that clean volume gradually drains away. This is remedied by unplugging everything, waiting a minute, plugging everything back in, waiting a minute, then starting playing again.
Issue isn't with the amp (I've gone straight to amp to make sure).
I have a few power hungry pedals on there, (Boss OC-3, EHX Memory Man w/Hazarai, Boss DD-3, Boss PW-10 v-Wah along with fuzz/drive pedals), could it be that there isn't enough power getting to the board?
I'm currently using two different supplies at the same time, one daisychained Boss PSU and one daisy chained Johnnyshredfreak brick thingy.
johnnyseven
Have you checked the current draw of the pedals against what the PSUs can provide? I've got two different Boss ones. One is 200mA and the other is 500mA.
Boss list theirs in the manuals:
DD-3 - 65mA
PW-10 - 55mA
OC-3 - 50mA
The EHX manual just says "The SMMH requires 9 - 9.6VDC at 200mA with a center negative plug. " Not sure if its current draw is actually the full 200mA.
I think some pedals just object to be daisychained with certain others though so it might be a case of trial and error to pin it down.
DD-3 - 65mA
PW-10 - 55mA
OC-3 - 50mA
I don't know if the current Diago one is the same as the JSF one, but at one point they were, with a ΓΒ£40 markup. LOL.
Here's what I've realised about power supplies: It's never a waste of money to buy a really, really good one. Nor a waste of time to actually sit down and work out how much you need, and all the other details.
I'm looking at a T Rex Chameleon as my next major pedal purchase. ΓΒ£130 makes it more expensive than most of the pedals it'll be supplying, but it's gonna do everything it needs to do and more.
Brandon W wrote:you elites.
johnnyseven
So, pedals are:
mcpherson Red Boost Mk:ii: ????mA (it's a treble booster, can't be much)
Fuzz Factory: <3mA (?)
Boss PW-10 v-Wah: 55mA
EHX Stereo Pulsar: 100mA
Boss DD-3: 35mA
Boss OC-3: 50mA
EHX Memory Man with Hazarai : 200mA
Behringer TU300: 70mA
Totalling about 550mA. So everything should run quite comfortably off the JSF. Shall plumb it all up and report back.
Boss DD-3: 35mA
Boss OC-3: 50mA
Have plumbed, and it all works. I'm guessing that previously, when I was using two supplies, the 200mA Boss one must have been overcome by whatever was on that it's daisy chain. I think I had the Pulsar on it because I would never have guessed that what is essentially a clever volume knob would use twice as much power as an OC3.
Got rid of the Fuzz factory because there wasn't space on the board. Added a compressor to help provide volume and bigness to the octave down sound as needed.
Sounds great!
Bit of surgery needed to get the power yoke into the delay:
Next bit of surgery will be to add a right angle figure 8 adapter to the JSF brick and cut a space in the board case for it to fit:
Sounds great!
Yeah, that might be a bit superfluous. I use the EHX more as a delay than a looper, and I'm experimenting now with two delays because I'm a massive Dave Navarro fanboi. Something else may well end up in that space, though.
I'm trying to restrict myself to things that I don't use often or that I'm not particularly effective with. Previously my boards would have been filled with drive and fuzz boxes, but now I have an amp with all the drive sounds I'll need.
